cdx2k1 wrote:Hmmmm.What if a fast car were not to have it?Say a modded car with no ABS..ideas/thoughts?
Depends on the particular OEM
ABS sytem and model car.
Each system is different. For example, different Mitsubishi models that I drive regularly... and
all with 4-wheel disc brakes for fair comparison.
Galant VRG -
ABS Only consistent in the rain for less experienced drivers. TOTAL BULLSHEIT
Caused accident because of increased braking distance.
RWD 1800 GSR Lancer -
No ABS - No real problems - well balanced - only needs a little more finesse in rain. (see 4WD 1800 GSR* - Needs bigger front discs.)
4WD 1800 GSR Lancer -
ABS - No real problems - well balanced - especially in the rain.
The main issue here (like RWD 1800 GSR *) is not enough front brakes to reduce fade when used in anger. Needs bigger front discs.
4WD Evo 6 RS2 -
No ABS - No real problems except excessive dusting -
beautifully balanced.
Lock-up at will in the dry - No fish-tailing - No bad behaviour... No drama...
It just
STOPS NOW... with change to spare from $0.10c too
- like RWD & 4WD GSR only
MILES better - just needs a little more finesse in rain IMHO.
Simply the best f***ing brakes I have ever used... period
BTW the new Evo 9 has new
ABS system, and it's supposed to be excellent.
As I said it depends on the car... My 2 cents.
