yakuza wrote:Here are some simple FRONT brake upgrades, with little or no modification.
Simple brake upgrades FRONT
AD22VF set up is a direct bolt on for B13, B14, Y10, N15, Presea (10” rotor and single piston calliper or complete spindle)
Can work on Y11 ( AD wagon), but must use complete spindle, disc pads are the same as U13 SSS bluebird, but carry a sample just in case when going to buy.
If you have an AD wagon, and don’t want to change to B14 spindles, you can use AD22VE callipers along with AD22VF rotors, AD22VE callipers bolt directly to AD spindles.
AD22VF set up can be found from GTiR pulsar RNN14, N15 VZ-R pulsar
W10 avenir 11” rotors and double piston callipers, direct bolt on for P10, P11, U13, U14, B15, N16, Y11-wingroad.
This set up can be found on the W10 Avenir and U13 bluebird that came with SR20DET, these disc pads are the same as A33 Cifero/Maxima.
11”rotors and large single piston callipers from the SR20VE equipped Y11 ZV-S, U14 and P11 are a direct bolt on for P10, P11, U13, U14, B15, N16, Y11-Wingroad also.
Simple brake upgrades REAR
The N15 VZ-R Pulsar complete rear disc brake set up is a direct bolt on upgrade for the B14, N15, Presea, they have 10” rotors and a larger calliper.
If you already have the tiny 9” rear disc set up, you can just swap the rotors and callipers.
Another way to get this upgrade is to re-drill P11 rear disc to 4x100, and use together with the P11 callipers.
The VZ-R and P11 callipers are the same, so they use the same disc pads.
A32/33 rear 11” rotors (5x114) can be re-drilled to 4x114 and swapped on to the P11/U14, using the A32/33 rear callipers.
A32/33 rear disc pads are the same as P11/U14.
VZ-R, P11, U14, A32, A33 all share the same rear callipers, the difference is the length of the mounting bracket, to accommodate the larger size rotor.
Boosters and Master Cylinders
For B14, N15, P11, U14 and Presea with ABS, the booster and master cylinder can be upgraded with the one from the W10 (SR20DET) that came with ABS , the ABS master cylinder has two outlets only.
If you don’t have ABS on your B14 etc, the booster and master cylinder from a non ABS W10 will work also, non ABS cylinder have 4 outlets.
Both W10 ABS and non ABS brake master cylinders come with 1” bore.
If you lucky you can get the W11 booster and master cylinder, same 1” bore, but the booster is considerably larger than the W10.
lost soul wrote:what size mc you having?was the pedal low before the upgrade?
racedriverpro wrote:I want an upgrade for a Y11 but not with the B14 set up. How much wud it cost?
