Monday, May 20th, 2013
- It is currently Sun May 19, 2013 10:14 pm
Post new topic Reply to topic  [ 230 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
RapToR
PostPosted: Tue Apr 26, 2011 11:06 pm
Offline
Authorized Dealer
FREE Delivery <--- Almost Anywhere !!!
Richard - 680-3752
_________________
PlayStation 3 250GB Bundle $2600.00 includes 1 Game..........................PlayStation 3 500GB $3000.00
Top
 Profile
RapToR
PostPosted: Tue Apr 26, 2011 11:10 pm
Offline
Model: 1800C
$230.00 - Retail
$149.50 - Wholesale [ sold by case ]
Quote:
PeliLite 1800 Flashlight
This one is built to last. The unbreakable ABS body resists chemicals, water and corrosion. The polycarbonate lens and focused Xenon lamp module produce a tight white beam that penetrates smoke and fog. The PeliLite 1800 flashlight is submersible, thanks to the o-ring seal and twist-on shroud that eliminates leaky switches. It is powered by 2 C akaline cells..
Image Submersible Image
_________________
Top
 Profile
RapToR
PostPosted: Tue Apr 26, 2011 11:11 pm
Offline
Model: 1900C
$000.00 - Retail
$000.00 - Wholesale [ sold by case ]
Quote:
MityLite 1900 Flashlight
Unlike conventional flashlights that have a yellowish beam, the MityLite 1900 flashlight uses a hi-intensity Xenon lamp that produces a powerful, bright beam. Use this compact flashlight to cut through thick smoke, fog, and dust. It is submersible and comes with a twist-on shroud. The 1900 is ideal for any situation. Powered by 2 AAA alkaline cells.
_________________
Top
 Profile
RapToR
PostPosted: Tue Apr 26, 2011 11:14 pm
Offline
Model: 2000C
$253.00 - Retail
$184.00 - Wholesale [ sold by case ]
Quote:
SabreLite 2000 Flashlight
This powerful flashlight was designed with one thing in mind: SAFETY. It carries more approvals than any other flashlight on the market today, making it safe for any hazardous environment or condition. The SabreLite is o-ring sealed with a twist-on shroud and comes with a polarity battery guard tray that safeguards against dangerous "outgassing" of hydrogen from an accidentally reversed cell. It is powered by 3 C alkaline cells, submersible, and has an ABS resin body which resists chemicals, corrosion, and extreme temperatures. Unlike ordinary flashlights that produce a yellow beam, the SabreLite's incredibly bright Xenon lamp produces a powerful collimated white beam. Pelican's SabreLite is the leader in quality and performance.
_________________
Top
 Profile
RapToR
PostPosted: Tue Apr 26, 2011 11:33 pm
Offline
Model: 9440
$7000.00 - Retail
$6325.00 - Wholesale [ sold by case ]
Quote:
9440 Remote Area Lighting System
The most innovative RALS unit to date, the 9440 moves fast to light up ravines, confined spaces, riverbanks... anyplace generator lights can’t go. Deployed, the mast extends 7 feet high, shining light over low obstructions encountered by traditional lantern style lights. With a 120 degree beam spread and up to 2400 lumens, the entire emergency area will have the light you need for a safe and swift operation.
The 9440 is maintenance free, using super tough LED lamp modules and NiMH batteries for up to 6 hours of continuous light.
_________________
Top
 Profile
RapToR
PostPosted: Wed Apr 27, 2011 11:15 am
Offline
_________________
Top
 Profile
RapToR
PostPosted: Wed Apr 27, 2011 2:14 pm
Offline
_________________
Top
 Profile
RapToR
 Post subject: Elmer's Glue
Offline
Authorized Distributor
Krazy Glue Original Formula - 2g Tube
$8.05 - Wholesale - 48pcs to box
$6.75 - Distributor - 48pcs to master case
Richard - 680-3752
Quote:
Product Description:
Krazy Glue Original Formula bonds to plastic, metal, wood, rubber, glass and ceramic. Features stay fresh container and one drop applicator.
_________________
Top
 Profile
RapToR
PostPosted: Wed Apr 27, 2011 2:15 pm
Offline
_________________
Top
 Profile
RapToR
 Post subject: CRC Products
PostPosted: Wed Apr 27, 2011 2:16 pm
Offline
Richard - 680-3752
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 12:22 pm
Offline
Model: 02005
2-26 Multi-Purpose Precision Lubricant, 11oz.
$400.00 - Wholesale [ sold by case (12pcs) ]
$360.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Plastic safe lubricant, penetrant and corrosion inhibitor that helps prevent electrical malfunctions caused by water penetration, humidity, condensation or corrosion. Restores resistance values and helps stop current leakage.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:05 pm
Offline
Model: 02006
2-26 Multi-Purpose Precision Lubricant, 1gl
$220.00 - Wholesale [ sold by case (4pcs) ]
$190.00 - Distributor [ sold by case (4pcs) ]
Quote:
Product Description
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:08 pm
Offline
Model: 02016
CO Contact Cleaner, 14oz.
$2400.00 - Wholesale [ sold by case (12pcs) ]
$2000.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Formula contains no known ozone depleting substances or VOCs. The non-chlorinated, non-flammable, plastic safe formula is an optimal alternative to CFC, HCFC and flammable contact cleaners. NSF K2 Registered.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:11 pm
Offline
Model: 02018
Lectra Clean® Heavy Duty Electrical Parts Degreaser, 19oz.
$580.00 - Wholesale [ sold by case (12pcs) ]
$560.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Effectively removes grease, oil, tar, etc. to increase operating efficiency of equipment. It evaporates quickly, leaves no residue and has no flash or fire point, making it an excellent alternative to 1,1,1-based cleaners. Use caution on some plastics.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:14 pm
Offline
Model: 02083
Di-Electric Grease, 10.5oz.
$480.00 - Wholesale [ sold by case (12pcs) ]
$450.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Non-curing silicone compound used for electrical sealing, lubricating, protecting and insulating. Waterproofs electrical connections and components. Improves electrical performance in adverse weather conditions.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:17 pm
Offline
Model: 02130
QD Contact Cleaner, 11oz.
$360.00 - Wholesale [ sold by case (12pcs) ]
$345.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Suitable for cleaning sensitive electronics and electrical equipment. Evaporates quickly, leaves no residue and is safe to use on all plastics. Use where lower flashpoint cleaners are acceptable. NSF K2 Registered.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:18 pm
Offline
Model: 03003
Technical Grade 3-36 Multi-Purpose Precision Lubricant, 11oz.
$330.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Plastic safe lubricant, penetrant and corrosion inhibitor that helps prevent electrical malfunctions caused by water penetration, humidity or condensation. Cleans, lubricates, penetrates and loosens corrosion.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:21 pm
Offline
Model: 03006
3-36 Multi-Purpose Lubricant & Corrosion Inhibitor, 1gal
$130.00 - Wholesale [ sold by case (4pcs) ]
$100.00 - Distributor [ sold by case (4pcs) ]
Quote:
Product Description
A versatile petroleum based compound that forms a clear, thin film that lubricates and protects against wear and corrosion. Multi-purpose product lubricates, protects, displaces moisture, and cleans.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:23 pm
Offline
Model: 03017
Gasket Remover / Paint and Decal Remover, 12oz.
$640.00 - Wholesale [ sold by case (12pcs) ]
$600.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Removes baked on fiber gaskets, gasket adhesives and sealants. Dissolves and aids removal of paints, lacquers, adhesives, and varnish. Contains no methylene chloride.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:24 pm
Offline
Model: 03040
Food Grade Silicone, 10oz.
$380.00 - Wholesale [ sold by case (12pcs) ]
$365.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Multi-purpose silicone spray for food processing and handling applications. Forms a colorless, odorless, non-staining film. Eliminates binding and sticking in most metal to non-metal applications. Meets FDA Regulation CFR 21-178.3570. NSF H1 Registered.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:26 pm
Offline
Model: 03050
Chain and Wire Rope Lube, 10oz.
$530.00 - Wholesale [ sold by case (12pcs) ]
$490.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
A special blend of synthetic lubricants, solvents and Molybdenum designed to keep chains and wire rope in peak operating condition.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:27 pm
Offline
Model: 03055
Food Grade Chain Lube, 12oz.
$450.00 - Wholesale [ sold by case (12pcs) ]
$410.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Blend of synthetic lubricants and mineral oil to keep roller drive and conveyor chains lubricated. Penetrates, lubricates and protects moving parts by reducing friction and wear. NSF H1 rated for incidental food contact.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:28 pm
Offline
Model: 03060
Screwloose Super Penetrant, 11oz.
$320.00 - Wholesale [ sold by case (12pcs) ]
$280.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
A no-compromise penetrant that attacks corrosion to free corroded fasteners & mechanical components. A super-fast, powerful, concentrated penetrating solvent that loosens rust scale & corrosion. Instantly penetrates minute & tightly fitted crevices.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:29 pm
Offline
Model: 03065
Food Grade Belt Dressing, 10oz.
$340.00 - Wholesale [ sold by case (12pcs) ]
$320.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
A Food Grade Belt Dressing to extend the life of drive belts by improving traction & allowing runs under reduced belt tension.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:31 pm
Offline
Model: 03080
White Lithium Grease, 10oz.
$290.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Superior lubrication and durability in any weather or temperature. Perfect for use as a break-in lubricant for bearings or as a general purpose lubricant and corrosion inhibitor for tools, machinery and equipment.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:32 pm
Offline
Model: 03081
Food Grade Machine Oil, 11oz.
$350.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
For use on food processing equipment. Penetrates to loosen rust, scale, dirt and corrosion. Meets FDA Regulation CFR 21-178.3570 for incidental food contact. Non-silicone formula is virtually colorless and odorless. NSF H1 Registered
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:33 pm
Offline
Model: 03083
Welder's Anti Spatter, 14oz.
$540.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Prevents spatter from adhering to surrounding metal surfaces during welding. Water-based formula allows easy clean-up without the use of solvent cleaners.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:36 pm
Offline
Model: 03084
Dry Moly Lube, 11oz.
$560.00 - Wholesale [ sold by case (12pcs) ]
$530.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Lowers friction, prevents galling and helps to reduce torque and energy consumption. High anti-friction and anti-seizure properties. Fast drying film resists dirt and dust build-up.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:38 pm
Offline
Model: 03086
Food Grade Penetrating Oil, 11oz.
$350.00 - Wholesale [ sold by case (12pcs) ]
$310.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
An effective and efficient general purpose lubricant for use on food processing equipment. It penetrates and loosens rust, scale, corrosion and dirt to free corroded parts and fasteners. Contains no silicones.
_________________
Top
 Profile
RapToR
PostPosted: Thu Apr 28, 2011 4:40 pm
Offline
Model: 03150
Contact Cleaner 2000 Precision Cleaner, 13oz.
$1100.00 - Wholesale [ sold by case (12pcs) ]
$980.00 - Distributor [ sold by case (12pcs) ]
Quote:
Product Description
Effective alternative to 141b-based cleaners when sensitive plastics are not a concern. Evaporates quickly, leaves no residue, has no flash or fire point and contains no Class I or Class II Ozone Depleting Chemicals.
_________________
Top
 Profile
Display posts from previous:  Sort by
Registered users: <<adrian>>, *$kїđž!™, 2311, 525isport, AD Solutions, alan1991, alien2012, Allergic2BunnyEars, andy111, anoojra, antoniomooreiconstatus, artman, autoconnect, avenall, AVSlimitedTT, azoturbo, badhabbits, bas, battlefield 3, BAZZINGA, bigboss#1, biller, Bing [Bot], brainchild, Brandon De Castro, Brandon Drksyde, Breeds, cage1330, carfreaks1023, CHEMAINE, christopherwilliams2, Chucky2284, ck4star, clintedan, coltspeed, computer, crock101, Davindra, Dedg93, deliah, desert punk, devrat, devsingh, dexx, djruncrowd, Dutchkinection, ello, evolve-x, Ghettovybz26, Google [Bot], Google Adsense [Bot], Google Feedfetcher, grimreaper009, gucci05, hindian, insane, ironman2012, Jaron, jerome2911, Jerron_speed, kishan25, kk80king, kreativ, lilpimp, living louder, M@nnie, madass, MADMAN1, mark2.0, mazdaspeed6254, megadoc1, metalhead, mikael, Mobile Whizz, MSN [Bot], musicboyz, Nismo2510, nismodriver, nnick, noise_maker, notnice, NR8, one_four_14, palmiste indian, pato, PH365Star, pjfred, playerskrew1, psycho68, rabbai222, rajvr497, raybic, realer, Reez100, ricardo1444, Russellgold, saxman642, scorpio_dream, shanemoon, shannonkangoo, shivapersad, short_man, showstopperz1, Slaughta69, smr_fingers, soundboi86, Soundstream_626, Spearhead, speedemonz, stev, striver, superman cre8tions, SweeP, trent, Trini Hookah, trini iceman, triniconceptz, trinihub, Tucson-anil, venomz, W2J, westaudio, wiked, XLR8, zorced, ~Vēġó~
You cannot post attachments in this forum
Search:
Powered by phpBB® Forum Software © phpBB Group
3NE-2NR
