If you have ever been driving and had your brake light come on, you may have been confused and wondered what it meant. In this article, we will explain why your brake light comes on, and how you can fix it.
The brake light on your panel may be on for several reasons. The fixes range from possible do-it-yourself projects to repair work. We have included possible causes for your brake light to be on, along with solutions for each. This will help you rule things out before scheduling a service appointment.
A car battery might turn on by itself for several reasons. A car battery charging issue is indicated when the battery light on the dashboard turns on. For detailed information and, more importantly for the solutions, keep reading.
5 Causes For Your Brake Light To Be On And How You Can Fix It
#1. Activated or stalled parking brake
Some of the cars have unique dashboard lights for the parking/emergency brake. But in other vehicles, it’s the same as the regular brake light warning. As you prepare to start your car, check to see if your brake light is on. If so, make sure your parking brake is fully released.
Put the e-brake on, obviously, to fix the problem. However, try to see a mechanic as soon as possible if you believe the emergency brake may be jammed or damaged.
If the parking brake is the issue, you should try to get it rectified as soon as you can because driving with the parking brake engaged causes extra wear and damage to brake rotors and padding.
#2. Low fluid flow in brake
Low brake fluid may be indicated by the dashboard’s general brake light. This is denoted in certain cars by a yellow circle with an exclamation mark in the center.
The vehicle still has enough brake fluid to work when the light is yellow, despite the brake fluid being low. See a mechanic or expert if it becomes red. Additionally, a flashing red light may indicate little or no brake fluid, which poses a major problem for the hydraulic system of the brakes.
To fix this issue you will need to learn how to check the brake fluid. By doing this you will rule out the brake fluid as the potential source of the brake light signal. In this way, you will also save money by doing it all by yourself.
You can either go to the auto shop and get it checked if you are unsure of doing it all by yourself. If you fill it or have it changed, either way, the brake light issue should get fixed immediately.
There is also a possibility of Leakage in the Brakes. Leakage can also be the cause of low fluid. It’s crucial to remember that leaking brakes could be the root cause of low brake fluid. Consider getting your brakes checked for leaks if the dashboard light problem is fixed after you replace or refill the brake fluid but return later.
A brake leak will need to be identified and fixed by an automobile specialist. Nevertheless, depending on where the brake leak is located and whether or not the brake system has received additional damage, the fix is typically simple and inexpensive.
This fix is best left to the experts because of the possible difficulty of the issue. The location of the leak, and the severity of the harm that could be caused if it is not correctly fixed.
#3. Your car may require new brake padding
In some vehicles, the dashboard brake light will signal worn-out brake pads or another issue with them since it signals a problem with the entire braking system. This is a useful feature.
You should schedule a visit with the car mechanic to get the brake pads tested and replaced. This should fix the problem.
Remember that keeping the quality of your brake pads helps maintain your safety, the safety of your passengers, and the safety of other road users. If this is the issue, get it fixed as soon as possible.
#4. Replacement of brake light bulbs
In many cars, when the rear brake lights are burned out or dim, the dashboard brake warning light will activate. This is very beneficial.
Have a friend stand behind your car (when it is in the park) as you pump the brake pedal to check for this problem. One or both of the red brake lights has to be replaced if neither of them lights.
The manual of your car will tell you what kind of brake light bulbs it requires. You may also get this information online. In reality, by entering your car’s general specifications and choosing the sort of light bulb you require, this website may assist you to identify the exact bulb you need for your vehicle.
#5. The anti-lock brake can be a problem (ABS)
Anti-lock brake systems are standard equipment on the majority of modern cars. Avoiding the wheels from locking up or the tires from losing grip when driving in slippery weather.
The dashboard light for this might be a separate ABS light, depending on the car, or it might be the same as the general brake warning light.
An electrical issue or issue with the wheel speed sensor would result in an issue with the anti-lock braking system, which would trigger a warning for the entire brake system.
How to Fix: To find out if there is a problem with the ABS and discover a fix, an automobile specialist can perform a diagnostic test.
Conclusion
Some of the causes and remedies for the brake and battery lights on cars have been covered in this article. If you can, solve the issue now to avoid it getting worse. If the issue is too complex for you to handle, consult a qualified mechanic who can correctly identify and resolve it.
